VI Scripting - Add a nested Case Structure
I am trying to add a case structure to the diagram of another case structure (see picture of example)
I created a VI to try to automatically find the outer case structure, and add the new case structure.
However, the new case structure does not appear to be getting created, but I do not see any errors generated.
Here is the code as I have it at the moment
Kenny
(1,987 Views)
Accepted by topic author Kenny_K
I see nothing wrong with the script itself.
However, you should do a Save of the VI at the end to make sure the changes are persistent.
Since your VI is opened dynamically and closed at the end of the script, I bet all modifications are lost.
Raphaël.
(1,969 Views)
DOH!
That was it, thank you!
Kenny
(1,959 Views)
