LIN BUS Monitor Data grayed out
Hi, i tried to start an Test with some actuators.
after a few days i get default Values, from the LDF, shown in my LIN Interface VI.
The Bus monitor shows also grayed out data.
What is the meaning of that? 
I've also read the Data with Canoe and there i can also see, the actuators stays at the target position.
(1,343 Views)
Hi!
This simply indicates that this frame was not transmitted for some time.
Possible reasons are stopped bus communication or frames which are transmitted just here and there.
You can even define if and after what time data is grayed out in settings > display.
I've to say, the german labeling is misleading, it speaks of "data without change", though repeatedly transmitted frames with unchanged data are NOT grayed out. No idea what the engish labeling is.
(1,276 Views)
