04-05-2024 02:02 AM
I was wondering if anyone can tell me if it's possible at all too modify how the VI Hierarchy displays data.
Its a really helpful tool for debugging but I would like to use it in documentation as well. I'm sure most people will know, when you try and print the VI Hierarchy, it will show the complete project hierarchy, not just the direct hierarchy of a particular VI (Which is what I would like to see). Additionally to that, the way in which names are displayed in the chart can lead to it being unreadable.
I'm basically asking, does anyone know the location off the code for the VI Hierarchy window (if it's available at all), and has anyone done anything with it.
Cheers,
Nik
04-05-2024 02:40 AM
@NikolaRistovski ha scritto
:.. when you try and print the VI Hierarchy, it will show the complete project hierarchy, not just the direct hierarchy of a particular VI
Open only that particular vi to view it's hierarchy.
04-05-2024 03:25 AM
For some reason you can't r-click the VI in the project and view the hierarchy, but need to open it and then choose view -> VI hierarchy. Maybe that should be a suggestion on the Idea Exchange or make a plug-in. 🙂
04-05-2024 03:38 AM
Cheers,
Nik
There isn’t one! This is from the original days of LabVIEW when the ability of LabVIEW to call VIs as integrated editor Window wasn’t yet present. This entire Window is programmed in C in the LabVIEW core just as a lot of other things in LabVIEW
04-05-2024 06:31 AM
That's a shame but at least I got a quick answer. Thanks everyone for responding so quickly!
I found the openGDS toolkit which can reverse engineer UML code from projects, maybe that might be worth looking into for creating class hierarchy diagrams, but I'm not sure I could automate the process without quite a lot of work.
Otherwise, I can just manually create this documentation by doing as pincpanter stated and taking screenshots.
