VI DAQ assistant
En utilisant le VI DAQ assistant, je n'ai pas acces aux entrées ni sorties du VI.j'ai réinstallé les drivers DAQmx croyant que c'etait ça le probleme sans succes...Quelqu'un a t il déjà eu ce problème?
Message 1 of 9
(4,238 Views)
Hello tdiak,
Please keep in mind that this the English section of the forum. (this is the French forum: http://forums.ni.com/t5/Le-forum-francophone/ct-p/FrenchForums)
So posting a French question over here might not get as much response.
Seeing that I do speak/write/read French I'll try my best to help you.
Can you give some more information of what you mean with "no access" to inputs or outputs?
Have you ever Used LabVIEW or DAQ Assistant before or is it your first time?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 2 of 9
(4,217 Views)
edit : wrong message, sorry.
Message 3 of 9
(4,214 Views)
Hello ThiCop
I'm new in this forum so i was not aware about the french forum.I will explain you the problem in  english
here the thing. i want to use the VI DAQ Assistant to generate a digital signal but when i configure the VI,
I have no entry to connect the vi with the rest of my program. The VI is there but i can't connect it with the rest of my VIs?
Thank you and hope to read you soon
Message 4 of 9
(4,197 Views)
Can you share a screenshot of how the Block Diagram looks like?
Can you also share your VI?
How familiar are you with LabVIEW?
Kind Regards,
Message 5 of 9
(4,193 Views)
As you can see, after the configuration i should have an arrow witch permit to extend the vi and see the entriens and output of the VI. in my case, i haven't the possibilities to connect with my DAQ
Thank you
Message 6 of 9
(4,189 Views)
Post your VI. You must have configured something wrong.  An image of a DAQ Assistant doesn't tell us anything.  We need to see inside it.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 7 of 9
(4,180 Views)
Based on this it's indeed difficult to see what's wrong.
Please do share the VI...
It will make the troubleshooting process way faster.
First guess:
Did you click ok or cancel after configuring your measurement channels?
Kind Regards,
Message 8 of 9
(4,177 Views)
Any news from your side?
Kind Regards,
Message 9 of 9
(4,140 Views)
