VB code
There is a function in excel macro which is programmed by VB code.
Can I call the vb code from LV somehow directly, or compilt it into dll or activex.
It is about open file and data convert.
Thanks.
Message 1 of 24
(6,650 Views)
Dll or ActiveX would be the way to go.
- Partha ( CLD until Oct 2027 🙂 )
Message 2 of 24
(6,643 Views)
Message 3 of 24
(6,639 Views)
Message 4 of 24
(6,636 Views)
Dll or OCX, which one is better, thanks.
Message 5 of 24
(6,610 Views)
Did you go thro' the link specified in muks' first reply?
Message 6 of 24
(6,599 Views)
The vi is in version 5, too early to open.
I am using 8.6, may you help to convert. Thanks.
Message 7 of 24
(6,589 Views)
Message 8 of 24
(6,584 Views)
Canot open, said memory full, error 3, canot open front panel.
Tried 2 PC.
Message 9 of 24
(6,577 Views)
You are right. I am able to view it and save it. and when i try to open it from labview after closing it i am getting the same error.
Message 10 of 24
(6,574 Views)
