Using web services in Labview
Hi!
I try to use http://zone.ni.com/devzone/cda/tut/p/id/7350 Calculator - web service by Labview vi. When I run my call sum.vi I get "Error 66 occurred at TCP Read in NI_InternetTK_Common_VIs.lvlib:TCP Buffered Read.vi:2->NI_InternetTK_Core_VIs.lvlib:URL Get HTTP Document.vi:1->call sum.vi" - error message. When I put url: "http://localhost/Math/Sum/3/1"- in browser I get answer to the browser but I want to call that service from vi.
How can I use Labview web services inside Labview?
(4,348 Views)
When you send a VI for review, please send all subVI's as well; it is difficult to troubleshoot your problem otherwise.
CLD | CTD
LabVIEW 2011 SP1 | TestStand 4.5
(4,333 Views)
I'm sorry "URL get HTTP Document.vi" is from Internet toolkit. I have NI Academic Site License which includes almost all Labview software.
(4,311 Views)
you are trying to connect to a webserver on your computer (i. e. localhost) and I guess you don't have any installed. Try another address and make sure that Windows does not block LabView to access the internet.
Jörn
(4,306 Views)
Jörn
Yes I try to connect localhost. I think that I have Labview webserver running because I can connect it by web browser (http://localhost)  and this calculator- web service (http:/localhost/math/sum/2/3) is running and I can call it by web browser.
From different computer:
1. By browser everthing is ok and I get answer from calculator- web service and see Labview webserver front page.
2. By Labview Vi (call sum.vi) I get same Error 66.
    - Server side  access.log says:
       "xxx.xxx.xxx.xxx - - [Thu Jun 25 11:34:21 2009] "GET /math/sum/1/2 HTTP/1.0" 200 295"
       where xxx.xxx.xxx.xxx is client computer ip.
I think that client vi can connet to the server.
I can read normal web pages from Labview Vi and get web page source. Could this be the problem?
When I call service from browser Log say:
"xxx.xxx.xxx.xxx - - [Thu Jun 25 12:16:51 2009] "GET /math/sum/1/2 HTTP/1.1" 200 295"
From Labview vi HTTP/1.0 and from Browser HTTP/1.1 ?
(4,299 Views)
