How does my application save the raw data to binary file?
Hi all,
At first, please look at my attachment. There is the part of my code (it is inside of a while loop) which saves a raw data from my firewire camera. I am thinking how does this saving process work? How does it save the data in each while loop's iteration time (pixels, rows and columns)? For example if I use 100x1000 8-bit image. There is also Set File Position.vi which makes next line after iteration (at least I think so?). It is important to know when I'm processing the data later with Matlab.
My second question:
If I set height = 100 and width = 1000 as parameters, image indicator from IMAQdx Grab's image out says that the image is "only" 1000x96 8-bit image. Where are "missing" 4 bits?
B R,
Jick
Message 1 of 11
(4,210 Views)
Heyy, maybe someone would know an answer to this question? 🙂
Jick
Message 2 of 11
(4,183 Views)
Hi Jick,
what is given in your "image size" (num of bytes) indicator?
Setting file position to end is ok for appending data to a file, writing binary files is just taking the byte stream given by that IMAQ function ( I don't have IMAQ installed, so cannot check what's coming out there).
Message 3 of 11
(4,179 Views)
If you are asking about my second question, I noticed that height from IMAQdx Grab.vi's session out is still same as I sent (100) but the image indicator from image out says that I have 1000x96 8-bit image. Why it is not 1000x100 8-bit image? Smiley Surprised
Message 4 of 11
(4,172 Views)
Hi Jick,
that doesn't answer my question... What is given in the "image data size (bytes)" indicator?
I don't have IMAQ installed nor worked with, so I can't answer on IMAQ specific issues...
Message 5 of 11
(4,167 Views)
Sorry, my bad. Image data size (bytes) gives 96064.
Message 6 of 11
(4,161 Views)
Hi Jick,
that perfectly fits your observation: 96*1000*1byte+64byte header(?). Smiley Wink
So you only get 1000*96 pixels from IMAQ...
Message 7 of 11
(4,156 Views)
Yes, I know that I get only 96*1000*1byte+64byte header. But my question is why I get it instead of getting 100*1000*1byte+header=100064  as set in the beginning (in front panels parameters control)? It kind of eats 4 of them?
B R,
Jick
Message 8 of 11
(4,148 Views)
Hi Jick,
well, as said before I don't have IMAQ...
Maybe you should attach either the vi or a picture showing the (full) IMAQ part instead of the file saving, which works perfectly Smiley Wink
Message 9 of 11
(4,145 Views)
Hi again,
Here is my whole CameraSoftware. It is a part of the bigger measurement program.
I hope you can find the solution of "lost 4 bits" 🙂
B R,
Jick
Message 10 of 11
(4,115 Views)
