Using variants in Call Library Function Node parameters
Can I use Call Library Function Node to send variant data?
Attached is a VI. Here's the C code:
int MM_FUNC mmDaqDll_407DB
    ( IN char *pcUdlPath
    , IN char *pcTableName
    , IN void *pvData
    int nStat = 1;
    //System::Object *varData = ((System::Object *)vData);
    MessageBox(NULL, pcUdlPath, pcTableName, 0);
    return nStat;
} // mmDaqDll_407DB()
I get the void pointer. I was hoping for a solution that did not use void*.
What is the best way to pass void data to a DLL?
(2,812 Views)
Hi Mefitzpatrick,
Here is a similar forum that addresses this issue:
http://forums.ni.com/ni/board/message?board.id=170&message.id=48886&requireLogin=False
They mention using the Adapt to Type property of the function node inputs, have you tried this?
Let me know if this doesn't answer your question.
Sappster
(2,793 Views)
