Using the "Make Current Values Default" as a control on the front panel
amazing! but I can't seem to separate the elements in each part of the array to be used in a different part of the program. Can this ven be done with building arrays and clusters?
mhaque
Message 21 of 23
(784 Views)
Unbundle by Name for Clusters
Index Array to break apart arrays.
Message 22 of 23
(780 Views)
BTW, my example does not use a typedef for the control type. I modifed the example you uploaded and you did not include the typedef. In your actual application you should use a typedef to define the cluster.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 23 of 23
(766 Views)
