Using set cursor.vi in an executable
I am running the VI and the executable on the same PC.
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
Message 11 of 19
(2,217 Views)
While I can't offer a solution, I can confirm the problem you're having. I'm on 8.2 and I can set any cursor in the VI, but not in the executable. I'm not sure why this is, maybe an applications engineer can shed some light on the problem.
Message 12 of 19
(2,184 Views)
Some of the cursors, such as the paintbrush mentioned in an earlier post, are only relevant in edit mode and you cannot edit a built application. I do not see anything in the documentation, but this may be what is happening. Are the inaccessible cursors ones which are only used in edit mode?
Lynn
Message 13 of 19
(2,178 Views)
You may be right.  Somebody from NI needs to confirm this.  However, if that is the case, I should not be able to set the paintbrush cursor in a VI that is running, because it is no longer in edit mode, but in run mode.
Also, I am not able to use custom cursors from a .cur file in a built application even though I successfully use them in a vi.
S G
Message 14 of 19
(2,171 Views)
This is actually a known issue that some of the cursors will not show up in an executable. R&D is aware of the problem and they are currently working on a solution. One workaround that I am aware of is referencing the cursor in a file. That is Create Cursor From File.vi plus the Set Cursor.vi. However, you will need a cursor file that has the cursor in it. I hope this helps!
Nick R
NI
Message 15 of 19
(2,139 Views)
Hi Nick,
Do you have a CAR# that goes with this issue?
Ben
Message 16 of 19
(2,066 Views)
The CAR ID is 3MJMKBSG.
Nick R
NI
Message 17 of 19
(2,058 Views)
Thanks all.  I am using a custom cursor file now, and that seems to be a workaround.  Be sure to include the cursor file (.cur) in your application if you plan to use this method.
S G
Message 18 of 19
(2,045 Views)
This was reported to R&D (# 3MJMKBSG) for further investigation.
Nick R
NI
Message 19 of 19
(1,961 Views)
