Using scan from string to convert a string into a number
I wanted to use scan from string to change a string into a decimal number, but when the string is, for example, 9.14123E-2 it just returns 10. How can I get it to return .00914 or 9.14E-2(as a number not a string). Would there be something easier than scan from string? I'm using labview 5.1. Thank you!
(4,068 Views)
Why not use
From Exponential/Frac/Eng
(4,067 Views)
use
"Functions->String->String/Number Conversion->Fract/Exp String to number.vi"
Also there are many other functions converting strings to numbers and back.
Good luck.
Oleg Chutko.
(4,067 Views)
I still get 10 if the input string is 9.15003E-2 when I use "From Exponential/Frac/Eng"
(4,067 Views)
Thanks guys I figured it out. There was a weird wire mix up because I used "replace" to put the "scan from string" in instead of wiring it up directly. Thanks!
(4,067 Views)
It does not happen on my computer
whether its labview 5.1.1 or 6.02
see attached 5.1.1 code
(4,067 Views)
May be you can checkout the attached example.
Perkash Mohan Lal
Institute of Semiconductor Technology
Technical University Braunschweig
(3,757 Views)
