Decimal String to Number
I'm using the express subVI Decimal String to Number (All Functions>>String>>String/Number Conversion) to convert the string 1.0008 to its equivalent in decimals. In the help, it's said that I can wire the type of representation I want (defaut(0 I32)). But it's not said what constant number to wire to that input to have a double representation and not see my string 1.0008 becoming decimal number 1 instead of 1.0008. How can I have that DBL Precision and keep my decimal part? Thanks.
Phil
(4,903 Views)
"Decimal String to Number" will only return base10 integers.
If you want the convert the string '1.0008' to 1.0008, use "Fractional/Exp String to Number".
Fading out. " ... J. Arthur Rank on gong."
(4,901 Views)
You are using the wrong function. Decimal String to Number will only return a decimal integer. You can wire a DBL constant to the default input but all that will do is have your integer represented as a DBL - it won't add any decimal places. Instead use Frac/Exp String to Number or use the Scan From String with a %f format string.
(4,902 Views)
oops wrong message
Message Edited by mr_nice on 12-01-2006 07:04 AM
(4,665 Views)
   Check out the attached program, it will certainly help you to get what you want.
Perkash Mohan Lal
Institute of Semiconductor Technology
Technical University Braunschweig
(4,650 Views)
