Using multicolumn listbox as indicator
I am trying to have data that I am collecting display on a multicolumn as it comes in. I don't know if you can do this and if you can I dont know how I can control where the data goes on the listbox. So can anyone explain this please?
(3,607 Views)
Use a property node with the property 'Strings []' to set the array (this also defines the order). Felix
(3,596 Views)
Thanks, I see the column header string[] and row header string[] but there isn't one for the other cells. How do I put the other information in though. Is there another property node. Sorry I feel like I should get it from here but I don't see a property node to put the data in.
(3,584 Views)
Accepted by kjs356
The correct property is ItemNames.
While you might find it tedious, if you have context help open, it will describe each property as you scroll through the list.
(3,581 Views)
