Using gtypes on WebVI
I am working on a WebVI and I cannot put a .gtype cluster on the panel. Am I doing something wrong or is that just an NXG limitation?
(4,072 Views)
Accepted by topic author heath89
Hello heath89,
Unfortunately, WebVIs do not currently support G types as controls or indicators on the panel. If you create an indicator from a G type on the diagram, no corresponding indicator is available on the panel.
Source: Debugging a WebVI - LabVIEW NXG Web Module manual
All the best,
(4,058 Views)
I have an array of clusters that have an LED. When I set the LED to be green with no boolean text, I can click on the indicator when it isn't running and it shows green, but when I run the WebVI and the LED goes on, it is green and says "on" in the boolean text. Is there anything I can do to change this behavior?
(4,048 Views)
heath89,
Can you help me attaching your webVI here? I would like to test the behavior and see if this is a bug or just some misconfiguration.
(4,018 Views)
here is a zip of the .gcomp with a webVI
(3,947 Views)
Hello heath89,
I tried opening your gcomp in LabVIEW 3.1.1, as well as 3.0.2; and it gave me a "File not accessible" error. I apologize for this inconvenience (I wonder what could be happening in the background).
If I can have a screenshot of both the front panel and the block diagram, I will try to replicate it in my side in a new gviweb.
Thanks again!
(3,912 Views)
