Labview Timers
Hi, I am new to LabVIEW and I don't know much about it but I did go through some online training to learn the basic stuff. I am working on a project and what I need to do is to be able to control home appliances. So what am doing at the moment I just used a simple code using a relay and LED to switch the LED on/off remotely which worked. Right now am trying to set a timer on the LED, for example, the user should be able to insert time he/she want the LED to be on so the code will include hours, minutes and second and after that time the LED should go off. I managed to create the code but it is not working properly.
Please help...
(2,823 Views)
Hi RuruM,
Probably need a little more detail regarding "not working properly" to give advice. Some brief thoughts:
  • Consider reading about and using a State Machine
  • You appear to have a tunnel with nothing wired hidden underneath the "Choose Performance" switch for the case structure
  • I don't see what will turn off the switch after starting - it seems like you're going to set it true over and over for many iterations (see State Machine for a way to move around this issue)
GCentralI'm attending the GLA Summit!
(2,751 Views)
Okay, Thank you I will look at it and get back to you. thanks alot.
(2,675 Views)
