Using digital waveform as timing source
Hi folks!
I have it a snag in my code, hopefully a new pair of eyes will shed some light on the issue. I am trying to output a digital word in one line (red highlight in picture attached), however I also want to output a digital waveform (kinda of a pulse train) in another line (blue highlight). The problem is that I want the digital waveform to be the timing source for the digital word output (as seen in picture)..But LabVIEW 8.5 gives back an error report saying that I can't output the digital waveform and use as a timing source....Smiley Sad
I am open to suggestion to work around this.
CheersSmiley Happy
P.S. : I have attached the picture and the vi
(3,749 Views)
Anyone? Kinda out of fresh ideas......
(3,712 Views)
Hi Rsilva,
Which board are you using? On most boards, you won't be able to run 2 digital output tasks simultaneously (because there is only one clock circuit on the board). So if you want to generate 2 digital signals simultaneously, you have to put them in the same task (and they will use the same clock).
One thing you can do is generating a pulse train with the counter on your board and use this signal as the clock for your digital signal generation.
(see example in LV: Multi-Function-Ctr Pulse Train Generation for AI Sample Clock.vi )
Thomas B. | CLAD
National Instruments France
(3,685 Views)
Yes, I want to output the pulse train in one channel and use it as (or use the same clock) to output the digital word, so they are in sync.
Isn´t that what I am doing in my VI?? Because LabVIEW gives back an error....
Any suggestions how to go about it?
I am using a NI-USB-6289 board. I will also check the example you suggested.
Thanks.
(3,662 Views)
