Is there a SubVI that will compute cross coherence of two signals?
I am trying to compute cross coherence between two time waveform signals to determine if one is a time-shifted version of the other, and if so what the time shift is.  I do not find a SubVI in LabVIEW that seems to perform this function.
(3,484 Views)
try the search function in the functions palette (in the upper right corner).
 signal processing-signal operation
What version do you use?
Greetings from Germany
Henrik
LV since v3.1
(3,463 Views)
If you have the Sound and Vibration Toolkit try going to the palette: Sound and Vibration » Frequency Analysis » Baseband FFT. Also try Sound and Vibration » Frequency Analysis » Baseband FFT » Baseband Subset and Sound and Vibration » Frequency Analysis » Zoom FFT.
The first one is probably your best bet.
Vince M
(3,443 Views)
I am using Version 8.6 with the Sound and Vibration Toolkit.  I have searched the functions pallet and find Coherence, Cross Power, and Cross Correlation, but these are not exactly what I am looking for.  I searched the NI website and returned the following link to a Blackfin Cross Coherence VI.  I think this is what I need, but I don't believe it is in my current product.  From the equation at the end, I may be able to build it, but with my level of experience, I wasn't sure I would get it coded right, and thought sure it would have already been built for 8.6.
http://zone.ni.com/reference/en-XX/help/371653B-01/lvblacklibdsp/bf_crosscoherence/
(3,438 Views)
Those VIs are only compatible for Blackfin, and use drivers and function calls that are specific to blackfin and embedded controllers.  Unless you are program embedded controllers I don't see these functions working for you.  However you could open up that function and try to replicate it in a regular SubVI using regular LabVIEW function calls!
Charley Dahan
Global Account Manager
(3,424 Views)
How do I open that function?  This appears to be the help file, and I was unable to see a link to open the VI itself to see how it is constructed.  SInce I don't have the Blackfin, I do not have the VI set it is referring to.
(3,415 Views)
If you have MathScript you can use cohere function,
Another way you can use Dual Channel Spectral Measurement Express VI
(3,387 Views)
