Using daq timer to trigger camera
Im using a NI-USB-6341, I think I saw that it has a hardware timer. Is it possible to have an input signal to the device start the timer which would trigger a digital output?
I have an input that I want to use to start the timer and have the timer send a signal directly to the camera to take a picture. I need to take a picture every 33.2mS and dont know if I can be accurate enough if I bring the signal into software first to then trigger the camera aquisition.
what my department usually does is take a galil controller and drive the trigger signal into that. Im hoping that since I already need the daq box I can avoid using the galil box also.
(3,984 Views)
Initial thoughts:
 - You could use a Counter Output (Pulse) property, Initial Delay, to delay your output pulse by a certain amount of time after the start trigger has been sent.
 - You could also try something akin to the example in this KB.
Paul P.
Applications Engineering
Highest Regards,
Paul
(3,942 Views)
I think Im going to do something similar but use the delay timer on the camera before taking a picture. I'm not sure I can change the parameter on the vi you pointed out while the system is running.
Thanks though
(3,910 Views)
