Using comparison operators to solve several different mathematical expressions is not clear
Though I found LabVIEW very interesting , still some of its basic fundamentals are not clear, like using comparison operators (>,<,..) for solving different
mathematical expressions. Please give example showing how to use such operators in advanced mathematical problems.
Best Regards,
Allawi
(3,210 Views)
Open the example finder (help...find examples) and look e.g. at the example named "Greater - Various uses.vi"
Please aks again if anything is not clear.
(3,207 Views)
The Greater-Various Uses.vi example shows how the function operating with different types of data. What I am looking for is how to use such functions
in selecting different mathematical expressions i.e..(working like logical if statement).
(3,200 Views)
@allawi1 wrote:
What I am looking for is how to use such functions in selecting different mathematical expressions i.e..(working like logical if statement).
You need to be more specific. A comparison operation IS like a logical IF statement and the result is either TRUE or FALSE.
What do you mean by a "mathematical expression"? What do you mean by "different"? Can you give an illustrative example?
If two alternative mathematical expressions should depend on the comparison, wire the comparison output to a case structure and place the two different expressions in their own case, for example.
(3,194 Views)
The following is what I mean:-
If X >= CONSTANT then solve EQUATION 1  else solve EQUATION 2.
Please construct a block diagram for this simple IF "logical" statement using comparisons functions.
Thanks.
(3,179 Views)
Have you worked through the on-line tutorials for LabVIEW? Your question is very elementary and should be covered by those tutorials.
Lynn
(3,173 Views)
