Using analog voltage output module(NI9263)
Hi all,
It is my first time to approach engineering, so the following question may sound silly.
I want to use the NI9263 module to output a voltage to control a relay(solid state relay).
I use this module to generate a 10V analog output; however, when I connect it to the relay, there is only 0.3V on the relay(measured by multimeter).
Do I need any additional device to generate 10V? Is there any solution with the current module(NI9263).
(3,116 Views)
Look at the current driver capability of the module and look at the current requirements of the relay. You'll need a driver. Look at the ULN200x series.
(3,108 Views)
Thank you for replying me.
What is current driver used for? Can it transform a analog voltage output into a cuurent?
Is it something like this
http://aud.dx.com/product/uln2003-stepper-motor-driver-module-blue-961149605#.UjhBw3--rwk
(3,090 Views)
