09-17-2015 08:57 AM - edited 09-17-2015 08:58 AM
@David-Baratheon wrote:
and make a local copy within that project folder?
Nope, project explorer does no file operations, it is just a way of organizing files. My point was that if you had a top level, and a bunch of sub VIs, you don't have to drag them over one at a time, if you just drag over the main, all of the dependencies are loaded and put under the dependencies section. But I also was suggesting other ways of adding multiple files to the project explorer quickly.
EDIT: Oh but one other option, within a project you can do a Save As which can duplicate the whole file structure and dependencies, making a new copy of the project too.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
09-17-2015 08:59 AM - edited 09-17-2015 09:00 AM
So I would do it outside of labview. Just drag and drop the VI and sub VIs from folder of old project to folder of new project?
I just thought that might cause some problems on bigger programs doing it that way. Thought it might have been better to do it within LabVIEW if there was a "proper method" of doing it
Save as is ok if you want to use an old project as a basis for a new one, but I want to copy 6 VIs from 6 different projects into one project
09-18-2015 07:03 AM
Just a bit of feedback.
I created 6 projects (five different functions plus a main project with a menu for calling the other five).
I created five autopopulating folders and directed each one to a project folder.
Because I used "main" as the main VI for each project, when I imported them all with an autopopulating folder, it raised it as a conflict.
I was only required to browse and find the specific main I was looking for, so it wasn't really very difficult to resolve, but could be difficult if you weren't the person who initially worked on the project or if you had a large complex project.
The error came up when I came to import each individual VI into the program selection menu VI.
