Using a checkered grid or input calibration paremeters in stereo vision
I would like to use a checkerboard grid, like a chessboard, to obtain the calibration parameters for the stereo view. Can anybody help me? There is the possibility to input the calibration data performed outside Labview?
Message 1 of 8
(3,826 Views)
I'm unsure what it is you are attempting to do.  Do you have a reference for the algorithm you want to perform?  Is the "checkered grid" a physical object whose image you acquire with one or two cameras?  Is it something you want to generate as an IMAQ image and use in some algorithm (what algorithm)?
Message 2 of 8
(3,798 Views)
Bob_Schor. I appreciate the attention. I have several images taken with two cameras that I would like to analyze. The calibration of the stereo system was performed, using MATLAB, with a chessboard. So, I have two options at the moment to generate the depth map of these scenes: use some VI that learns the camera model from a chess board or find some way to input the intrinsic and extrinsic parameters, that I know, in the stereo session of my VI. I don't have the cameras now, but I would need to have the VI that performs the depth map when joining the devices.
Message 3 of 8
(3,788 Views)
OpenCV has functions for this... Not sure if that helps. You can use OCV from Python... And Python from LabVIEW 😁.
https://docs.opencv.org/2.4/modules/calib3d/doc/camera_calibration_and_3d_reconstruction.html
Message 4 of 8
(3,765 Views)
It is a possibility. I had'n thought this way. I knew I could use Matlab from Labview but not Python. I will analyze that approach. Thank you.
Message 5 of 8
(3,758 Views)
I am working on an open\free OpenCV library for LabVIEW.
Those functions are advanced though, and where simple functions can be used directly from the OCV dll, advanced functions will need a wrapper. I'm not that far in the process. A few more months is optimistic 😒.
Message 6 of 8
(3,755 Views)
Really? Who am I to try? I couldn't even install OCV.
Message 7 of 8
(3,747 Views)
From Python it doesn't seem too hard: py_setup_in_windows. Of course if you're not familiar with Python there's a learning curve.
There's also OpenCVSharp, one of the OCV .NET wrappers, but you still have to figure out the .net<>LV interface. And, IIRC, it's only has some of the advanced stuff. Checkerboard calibration is there, but 3D I don't know. It doesn't support OCV GPU features well, AFAIK.
Message 8 of 8
(3,744 Views)
