Using VI Server
I have attached a vi that I am working with. I have never used VI server before and I am having trouble with some minor areas. I ran this vi, although I know it is missing some stuff, and I didnt get any errors. I have this vi open another vi that runs a test. This test runs and when it ends, I want to send a signal back to the VI Server to tell it to close. Can anyone point me in the right direction?
Ron Deavers, CLD
(2,822 Views)
You can do this with two invoke nodes coming after your "open VI ref". On the first one, which is set to RUN....wire a "true" into "wait until done".....the second invoke node can be your stop/close. This will give you the desired funcionality of closing when complete.
-Brett
(2,795 Views)
