MySQL database access (example provided)
I am having the hardest time figuring out why I don't see the right data when I try to access a MySQL database on the same computer I am running LabView on. When I look at it with the MySQL Control Center (that you can download from www.mysql.com) all the data is easy to access on my local server 'MWC-PROGRAMMER' in the database 'vistavision_db'.
However when I try to access this db with LabView (the VI that I use is attached) I get very different data; almost like configuration tables. No matter what I do, I can't seem to find the 'vistavision_db' anywhere, and only ever get databases like 'msdb', or sometimes, 'master'. Please see my attached VI for more specific details, like ODBC settings, etc.
What do you think I am doing wrong?
(4,576 Views)
One thing that jumps out at me is that you say you're using a MySQL database but in your program you have a Microsoft SQL Server ODBC setup. Which is correct? You have to use a MySQL ODBC driver with a MySQL database.
(4,574 Views)
I had a feeling it might be something ridiculously basic.......
It is definitely a MySQL database, but when I try to 'add' a new ODBC data source, I don't see a specific MySQL driver. Is there something I have to download for this? These are the drivers that I can select from (what the non-English means is beyond me!):
Driver da Microsoft para arquivos texto
Driver do Microsoft Access
Driver do Microsoft dBase
Driver do Microsoft Excel
Driver do Microsoft Paradox
Driver para o Microsoft Visual FoxPro
Microsoft Access Driver
Microsoft Access-Treibir
Microsoft dBase Driver
Microsoft dBase VFP Driver
Microsoft dBase-Treibir
Microsoft Excel Driver
Microsoft Excel-Treibir
Microsoft FoxPro VFP Driver
Microsoft ODBC for Oracle
Microsoft Paradox Driver
Microsoft Paradox-Treibir
Microsoft Text Driver
Microsoft Text-Treibir
Microsoft Visual FoxPro Driver
Microsoft Visual FoxPro-Treibir
National Instruments Citadel 4 Database
National Instruments Citadel 5 Database
SQL Server
Message Edited by Synap on 03-09-2005 09:17 AM
(4,573 Views)
I've only used MySQL briefly and I don't remember exactly where the driver came from. I think it would have been part of the original application installed on the server. I would start at mysql.com and if that doesn't work, you might try googling for it.
Message Edited by Dennis Knutson on 03-09-2005 08:24 AM
(4,566 Views)
Thanks Dennis! Problem solved!
For anyone who came to this thread searching for a solution, I went to this link: http://dev.mysql.com/doc/mysql/en/installing-myodbc.html
...and downloaded the installer for the MySQL ODBC driver. After installation, I went to the Data Sources (ODBC) manager, and it was real easy to setup (after I selected the correct port!).
Labview accesses the MySQL database like a dream now.
Thanks again.
(4,554 Views)
