06-22-2018 02:44 AM
I use Tesseract.exe in my application (LV13) rather rudimentary (with repeated disk access) and I would rather use the DLL (or .NET) available.
But I did not understand everything about the classes used ...
Here is the rudimentary version but works well:
And what I would like is something like below (only for example, I'm not sure for the functions used...) :
Would someone help me on this subject ?
Thanks.
06-22-2018 04:19 AM
can you upload the dll file with the command list..
06-22-2018 07:16 AM
06-22-2018 07:27 AM
Do you have a header file with the dll? Without the header file we cannot wrap the dll file as vi as we do not have full command syntax .... or any pdf or document file which contains the command list?
06-22-2018 09:34 AM
No I didn't find it...
I found these links, maybe they can help :
https://github.com/tesseract-ocr/tesseract/wiki/APIExample
https://www.c-sharpcorner.com/article/ocr-using-tesseract-in-C-Sharp/
09-03-2021 08:58 AM
Can you share the Tesseract.exe with me.
Thanks a lot.
Fred
09-07-2021 07:14 AM
Hello Fred,
Do you mean the file to install the language ?
Or do you need information ?
Bruno.
