Using Telnet in LV2016
thanks for your response but can you be more specific because it doesn't work when i copy the file internet from addons LV 2011 to the same file in LV2016 ( without installing the internet toolkit )
so please can you share a VI example how can i replace the telnet functions (read , write ...)
Message 11 of 18
(1,524 Views)
As always, "doesn't work" is not enough. What exactly does not work? The application can be compiled? It won't work during execution?
Please be more specific.
Paolo
Message 12 of 18
(1,523 Views)
NO i can't compile the application , i have this error as shown in the capture and i think it's because i don't install the internet toolkit  only if install LV 2011  first but i'm working in windows 10 .
any suggestions please
Message 13 of 18
(1,520 Views)
Open the broken vis and see what's wrong.
Paolo
Message 14 of 18
(1,516 Views)
the error is from the telnet functions read and write , i need to install the internet toolkit but i can't without installing LV 2011 !! and i'm working in Windows 10
Message 15 of 18
(1,512 Views)
Ok it's a license problem, I didn't think about. A workaround may be to install LV 2011 on your Windows 10 machine and activate the library. Is the activation code the same for both versions? Then, you can do what I suggested (I did the same with LV 2011 and LV 2017 on the same machine).
Paolo
Message 16 of 18
(1,505 Views)
yeah i did it and it work but i can't install LV  2011 because i need to send it to a client and it's not appropriate to tell him install both versions of LV .
any other suggestions please
Message 17 of 18
(1,498 Views)
I guess the client does not have the whole development application installed? Don't you distribute an exe with an installer? In this case, once you compiled the program to an executable, you only need the LV runtime (2015 or 2016).
Paolo
Message 18 of 18
(1,496 Views)
