Using Telnet in LV2016
Hi all,
i'm upgrading VIs form LV2011 to LV 2016 and i have some errors with Telnet VIs ( i was using internet toolkit for LV 2011 ) any suggestions Please
Message 1 of 18
(6,304 Views)
  The "typedef" is missing. May be you have the folder or deleted it . Some of your subvi's are also connected to this typedef.
Message 2 of 18
(6,285 Views)
Hi Ahmed,
which problems?
This has been discussed 5 years ago
Message 3 of 18
(6,277 Views)
Accepted by topic author ahmedkochbati92
The Network toolkit was deprecated and the Telnet library was never added into the base LabVIEW.  You will need to copy the library from an older version in order to use them.
Message 4 of 18
(6,274 Views)
i have the labview internet toolkit 2011 , so where exactly i need to copy this file ?
thanks
Message 5 of 18
(6,270 Views)
C:\Program Files (x86)\National Instruments\LabVIEW 2011\vi.lib\addons\internet
Copy the whole directory.
Paolo
Message 6 of 18
(6,262 Views)
yes it works thanks a lot
Message 7 of 18
(6,251 Views)
Hi crossrulz,
your solution work only if i have LV 2011 installed in my PC because without it ican't install the internet toolkit but my gaol from upgrading to LV 2016 is to be able to run these VIs in Windows 10.
so any suggestions please
thanks
Message 8 of 18
(6,210 Views)
If you copy the directory C:\Program Files (x86)\National Instruments\LabVIEW 2011\vi.lib\addons\internet into
C:\Program Files (x86)\National Instruments\LabVIEW 2016\vi.lib\addons, you should be able to reuse your project, simply recompiling the internet toolkit code with the newer LV version
I don't use Telnet VIs, but this way I succeeded in using other toolkit VIs in my LV 2017, upgrading from LV 2011.
Paolo
Message 9 of 18
(6,208 Views)
That's why you should copy it and keep a copy in a safe place.
Personally, I just use the TCP library since a large majority of Telnet interfaces I have needed never used all of the special coding; turns it into a straight ASCII protocol.
Message 10 of 18
(6,195 Views)
