Using Tabs with Subvi's
I wish to have each page of a tab control be used with a subvi. One for graphs, one for data entry,etc and wish to have the tab page number start and stop the selected subvi. Up until now I have been using 'run on open' and a seperate stop button for each subvi. I tried creating dummy tab pages and local variables and it works but is clunky. The problem is that I can't read a tab page number selected from a main program while I'm in a subvi. Thanks, Jim W
(2,679 Views)
"The problem is that I can't read a tab page number selected from a main program while I'm in a subvi"
Yes you can!
When you call the sub-VI, pass it a reference to the the tab control in question.
Inside the sub-VI, use the "value" property node to check the displayed tab page. If it changes, the sub-VI should terminate.
Ben
(2,679 Views)
