Using Segmented Memory of Agilent InfiniiVision MSO7104B Mixed Signal Oscilloscope
Dear All,
I am using an Agilent InfiniiVision MSO7104B Mixed Signal Oscilloscope to acquire the waveform data. In order to make the acquisition faster, I am using the segmented memory of 100 segments right now. I want to write the waveform data from each channel to a file using LabView. When I save the data, I only found one segment has been saved. I can save all the segments using the "for loop" over all segmented index but that is making the writing very slow. Do you know any other way, where I can save all the segments without using a "for loop"? I have seen in the manual that there is a command ":SAVE:WAVeform:SEGMented?". I am wondering how I can use this command in LabView? Any help is very much appreciated. Thanks!
(1,121 Views)
Look inside the driver VIs for a clue on how to use it.
Bill
CLD
(Mid-Level minion.)
(1,105 Views)
Hi Bill, thanks for your response. I have downloaded the driver from http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=1E5E6D70FCA569A3E0440003BA7CCD.... I tried to find any sub VI which is dedicated to saving the waveforms but didn't find one.
(1,066 Views)
