Using Replace Array Subset to populate 2D array
I am attempting to use "Replace Array Subset" to populate a 2D array. However, when I replace one row, the previously replaced row is cleared. I can't figure out what I'm doing wrong. I created the attached vi to illustrate the problem. I tried "Insert Into Array" with the same result.
John
(4,119 Views)
Hi John
Could you attach your vi as LV7.0? There are still lots of users which do not use LV7.1.
If you don't know how to do that:
1. File-Menu
2. Save with options...
3. Select Save for previous version in the new window
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(4,113 Views)
You need to use a shift register, check the online help for details. See attached modification (LabVIEW 7.1)
(Also make sure you place a delay in your loop, it is not necessary to repeat the same operation millions of times a second. Use an event structure so the loop only spins if needed.)
(4,113 Views)
Ah - the mighty wizard did the job...Smiley Very Happy
So there's no need to attach it as LV7.0.
I assumed it would be a missing shift-register - but without looking at the code...
Using LV8.0
(4,109 Views)
Thanks for the feedback guys. Altenbach, your solution certainly does what I'm trying to do. Thanks for taking the time to show me. I know what a shift register does and how it's used, but I don't understand why I need it in this case. Doesn't the array retain a value once set? if I'm not resetting a particular element of the array I would expect it to retain its old value. Can you offer any insight into what's going on here?
Thanks again
John
(4,096 Views)
Follow the money wire!
At every loop iteration, you take the ORIGINAL array (all zeroes!) from the input tunnel, replace the desired row (only one!), and write the entire table. All data will be fresh. There is no place where old data is retained. Try some execution highlighting for illustration. 🙂
(4,090 Views)
