I am trying to configure an HP34401A multimeter for use with LabVIEW
7.0, IVI 2.2 and MAX 3.1.1. Although I have the VIs in instr.lib, there
is no entry for it in MAX under IVI Drivers > Advanced >
Instrument Driver Software. I tried to install the .msi file downloaded
from the instrument driver network, but it complained about the
presence of an existing driver.
How do I remove the existing HP34401A software and reinstall it so that I can use this device?
The driver that's installed with LabVIEW is not an IVI driver. To remove the old one, rename the folder under instr.lib. I said rename and not delete in case you want to use the native LabVIEW driver at some point.
