Using Polynomial Scale
I've never scaled input from a DAQ, so I'm not sure if I'm approaching this the right way.  I'm trying to scale the output of a wind velocity sensor using the data provided by the manufacturer, which is as follows:
Flow Velocity (m/s)           0                2                4                  6               8                10
Output Voltage (VDC) 1.00±0.24    1.94±0.24    3.23±0.24    4.25±0.24    4.73±0.24    5.00±0.24
So I think what I need to do is generate polynomial coefficients and use those to create a scale for use with DAQmx.
My problem relates to the x vs y values.  I assume that the scale works by taking a reading, putting it on the x axis, and finding the y intercept of the polynomial equeation.  To generate those coefficients I am using the Curve Fitting VI.  If I put Flow Velocity on the X axis and Output Voltage on the Y, the VI generates a curve that looks just like the curve from the data sheet of the sensor.  But if I need to use the X axis as the input I have to reverse this.  When I use Voltage as the X axis, the Curve Fitting VI doesn't seem to put out a curve that looks right.  I've messed around with the power or the polynomial or other curve fits but it doesn't seem correct. I've attached a VI to show what I mean.
Not sure if I'm even going about this the right way.
(3,971 Views)
I don't use express VIs, and you failed to attach all subVIs, so here's what you could do instead. (LV 8.2)
(3,954 Views)
Thanks you very much for the response and for building that VI.  Very helpful. I'm going to need to study this for a while to understand it.  The program can't seem to find a subvi "Ramp Pattern by Samples".  Any chance you could post it?
(3,942 Views)
By the way, why don't you use express VI's?
(3,941 Views)
...because I don't use dynamic data. 😄
(... and vice versa 🐵
(3,934 Views)
(3,918 Views)
Hi Live,
it seems you use a Base version of LabVIEW or your old version didn't know those Ramp function yet...
See attachment for a simple replacement (no error checking included)!
(3,910 Views)
