‎03-25-2014 07:04 PM
I am using an Orangutan SVP board and need to read information (namely, speed of a motor, temperature from a temperature sensor, pressure from a pressure sensor, all connected to the Orangutan) to a labView GUI I've set up. I also need to communicate to the board if a button on the GUI is pressed.
I've downloaded VISA and instrument drivers, but need help reading all the different types from the USB, not just one piece of it.
I also will need to connect a PointGrey video camera to this GUI to display continuous video, if you would also like to give me pointers on that.
I am brand new to labView and any help would be greatly appreciated.
‎03-26-2014 10:48 AM
Hi Showie6,
Where did you find the LabVIEW drivers for the Orangutan SVP board? I'm having trouble finding any NI supported drivers for your device?
‎03-26-2014 10:55 AM
I've just realized I downloaded the wrong drivers. Is there a way to use the labView software with this board since, like you, I'm not seeing any for the Orangutan?
‎03-27-2014 08:16 AM
I have not found any NI or 3rd party drivers for that hardware. You would have to contact the manufacturer to see if they have anything. A proper driver is neccessary to interface with LabVIEW.
‎03-27-2014 11:33 AM
Ok, I have looked into serial commications with my board, and LabVIEW is recognizing the comms for that. Am I able to use the serial communications to get different pieces of information, like I was trying to do via USB?
‎03-28-2014 10:18 AM
Hi Showie6,
Because we do not support that product I am not familar with what data can be accessed with it's interfaces.
