Using ModelSupport2.dll in LabView without TestStand
I would like to use the ModelSupport2.dll purely in a LabVIEW environment as either by a "Call Library Function Node" or "Active X" or ".NET" without using TestStand.
In particular I would utilize the the "DisplayPassBanner" and "DisplayFailBanner" functions. I want the banner pop-up's so I can provide a consistency between applications that don't use TestStand and those that do.
The DLL call requires a numeric input "context" which I am not sure what it needs for a reference number.
In teststand it is passed an "Object", "CVI Active X Automation Handle", "By Value" from the "ThisContext"
How replicate this or create equivalent in LabVIEW
Any suggestions appreciated
A
(3,710 Views)
In addition this is in LabVIEW 8.5.1
A
(3,704 Views)
A,
if you are looking into the sources of ModelSupport2.dll (the sources are included as LabWindows/CVI project and the needed C files), you will see that the display banner functions do access the object referenced by the parameter 'context'. The context is a reference to the dataset of a running TestStand execution when called from the TestStand process model.
So it will not be possible to use those functions if you are not going to use TestStand/running an actual sequence.
There are, however, two ways you can go for:
a) Design a LV VI dialog such way that it looks like one of the banner and call it as a subVI.
b) Use the LabWindows/CVI sources of ModelSupport2.dll to copy the banner dialogs into a new CVI project (from modelpanels.uir) and create similar functions into a custom written dll which do not require the ActiveX handle 'context' to be passed.....
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,702 Views)
This is what I thought, thanks for the suggestions.
A
(3,694 Views)
