01-03-2012 08:17 AM
I am working on a program that relies on the user pressing a Boolean button in order to move out of a loop. The program was working fine, then I began using property nodes and now when I ask for the button's value using a property node, I receive the data type "VOID":
When I have the control connected directly to my stop button it will work, but if I connect the property node it will give me a data type mismatch error. I have tried removing the button and property nodes related to it and replacing them, but it is not improving anything.
Anyone have any thoughts?
Michael
Solved! Go to Solution.
01-03-2012 08:29 AM
Is your boolean control set to Latched mode? You cannot have Value property nodes for latched booleans
see here: http://digital.ni.com/public.nsf/allkb/0774F8F0498017B886256F080066E2E3
01-03-2012 08:32 AM
That was it.
Thanks!
