Using Labview to control spark ignition
The TO never talked about a rotating engine... and a speed/power control system
if it's just a chamber with 2 valves and the igniter (triggered by TTL an drivers) with maybe ~0.1ms timing,  a DO card with >10kHz  updaterate hardware clocked should do it.
Greetings from Germany
Henrik
LV since v3.1
Message 11 of 14
(818 Views)
Thank you for your time. I understand your point but my system does not have a crankshaft. Its like I am taking the ignition system of a car and using to switch on my stove at precise times.
Message 12 of 14
(785 Views)
Message 13 of 14
(782 Views)
Yeah, I assumed too much and jumped to the conclusion that "ignition" would also mean automotive.
Do you have a DAQ device with counters?  They're great for apps that need precise, repeatable hardware-based timing.
-Kevin P
Message 14 of 14
(770 Views)
