Using LabVIEW with NI VeriStand
I'm trying to use Labview with NI Veristand, when I follow the white paper here:
http://www.ni.com/white-paper/11135/en
I do not see the same menu as detailed in step 4 (NI veristand is not listed in the menu - see attachment). I have NI Veristand installed on my computer.
Do I need to install an additional add-on?
(3,080 Views)
Is your VeriStand version newer than the LabVIEW version?
It could be some versioning discrepancies, perhaps?
Try putting the VI's in a project.
Br,
/Roger
(3,075 Views)
I'm running Labview 2011 SP1 & Veristand 2011 SP1.
(3,065 Views)
Accepted by topic author jtur
In what order did you do the install?
Installing VeriStand before LV could be a problem.
I got the same version(s) of VS and LV that you got, and that menu alternative is avaliable for me.
Br,
/Roger
(3,061 Views)
Thanks Roger - I installed Veristand and then Labview, this could be my problem I will try and uninstall / reinstall in a different order.
(3,059 Views)
