Using LabVIEW's FFT
The LabVIEW FFT uses the usual eponential term:
e^(-i*2*pi*k*n / N)
Is there a way that I could modify this term to include a constant and otherwise perform the FFT as usual? i.e. replace the above exponential term with something including a constant, "c":
e^(-i*2*pi*k*n*c / N)
I'm actually using a 2D FFT on a square 2D array but hopefully a solution to the 1D case above would be easy to apply.
If this is more of a math than programming problem, a point in the right direction would still be greatly appreciated!
(3,240 Views)
Accepted by topic author Orbital
The only parameter you can control is N, the number of samples in the dataset.  You can try making 1/N' = c/N.  See if that will give you the results you expect. If c < 1, then N' > N and padding of the input data will be required.  For the opposite case a reduction of the input is needed.  Be careful about how the data is reduced so that you do not lose information.
Lynn
(3,228 Views)
Thanks very much!
I'm not sure if I still need it or not but I think that will work if I do.
(3,182 Views)
