Using LV 8.6 to access database created in MS SQL Server Management Studio
I am using Labview 8.6 to access a database created in MS SQL Server Mgmt Studio, using LabSQL ADO utilities. I don't have LV's add-on DB connectivity toolkit, but just the ADO utilities. Can i do it? If yes, how? I have no experience whatsoever in connecting and accessing data from a DB. An example would help.
(3,817 Views)
As for my opinion you cant access without DB connectivity toolkit.
Silver_Shaper | CLD
(3,806 Views)
Nonsense.
With LabSQL, you should first find an on-line SQL tutorial and refer to the Microsoft help files. I would recomend creating a UDL file. This is the connection string you use for the ADO Connection Open function. You might want to to get a little help from the db administrator. You'll certainly need help in getting a login and password.
There are examples that come with LabSQL
(3,797 Views)
Indeed Denis,
LabSQL works perfectly fine.
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's 😉
LabVIEW 5.1 - LabVIEW 2012
(3,784 Views)
How do I create UDL file for a database created in sql server management studio?
(3,729 Views)
That might be a question that is better suited for MSDN, considering this is a Microsoft product. It might helpful to look over the documentation here: http://msdn.microsoft.com/en-us/library/ms174173.aspx
(3,704 Views)
