Using DAQ Assistant with a remote system
Hi mihamm,
you are using a WindowsVista computer with an old LabVIEW version and the same PXI chassis as GriffE?
When you have a similar (but not the same) problem then you should post your own question…
Message 11 of 12
(458 Views)
thank you for your answer.
I started a new topic, you can see it here:
https://forums.ni.com/t5/LabVIEW/Data-Acquisition-with-Remote-System-PXIe/m-p/4048504
Best regards
Message 12 of 12
(449 Views)
