Using Console Out on cRIO 9075
I wanted to use the Console Out on the cRIO 9075 I have for a quick check of status messages and possible errors.  I was able to find RT Debug String VI from the following page.
http://zone.ni.com/reference/en-XX/help/370622K-01/lvrtvihelp/rt_debug_strings/
But for some reason I am getting the following error.
Error# -1073807246
VISA: (Hex 0xBFFF0072) The resource is valid, but VISA cannot currently access it.
I can see the normal output from the port when the cRIO is started.  So is the port just blocked for this type of access on this particular cRIO model or am I doing something wrong?
Thanks for your help
Joe
(2,722 Views)
Joe,
There are a number of different possible causes for why you're getting this error. Some common ones I see are people either not closing resources properly or having another program taking that port. Please check his document and see if any of these troubleshooting steps work for you:
"NI-VISA Error -1073807246 Cannot Access Resource"
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NeQSAU&l=en-US
(2,696 Views)
