How to programmatically change the y-scale names of a multi scale waveform chart
Hey guys,
I am currently working on a project for school where i have to create a multi functional data acquisition application which should be able to take in data from various DAQmx devices. This community has been a great help so far getting the application working but i am currently struggling with a simple issue where i am unable to programmatically change the scales names of my waveform chart to the desired quantity.
Because of this issue i have to manually change the scales names of the waveform chart to the appropriate quantity from the properties menu before stating the application.
I have uploaded the simplified version of the VI i am currently using where i am able to programmatically change the scale name label of one scale via the waveform chart property node
Any help on this will be greatly appropriated.
Jonathan
(2,764 Views)
Accepted by topic author debonjo
Hi debonjo,
I am not sure if I understand your question, you can try it with "active y scale" property in front of "label text" property, like this:
MOJO
(2,753 Views)
Yes, that did the trick!
Many thanks to you MOJO!
(2,750 Views)
