Using Brute Force in an array
hi GerdW,
i tried it your way but this is what i was getting array 1 input and array 2 output
but what i was trying to do is this which is file11 if you can look at which i have uploaded a little earlier if you cant ding it i can upload it again.
Message 11 of 22
(2,110 Views)
Hi hasnain,
The last image looks correct for me - as much as I can tell from just that image.
That image is entirely unclear for me. I have no idea why/how you would empty strings in the output array - you didn't say so in your description of the problem.
Generic advice:
When you have problems with your VI then its a BAD IDEA to attach just some images of a frontpanel. It would make so much more sense to attach the VI instead!
Specific advice:
I prefer VIs saved for LV2017 (or older). LV2018 is rather fresh and not everybody has it installed yet (like me).
Message 12 of 22
(2,102 Views)
To me 11.png ("requested result") looks the same as 12.png ("your solution"). Main difference in 11 is, that the result array is transposed, so the 2D array has its values "in the same direction" as the input 1D array.
And somehow it only shows values for the first two (constant) input values, and both B's. I assumed that the output 2d array in 11.png was just a simplification showing the important values, rather than all. Hasnain, can you help us here?
Maybe like this: Is this way you need? If not, could you give some correct test cases?
Input: 10
Output: 10
Input: 00B
Output: 000, 001
Input: 10BB11
Output: 100011, 100111, 101011, 101111
Input: BBB
Output: 000, 001, 010, 011, 100, 101, 110, 111
 And shall the result be inside an 1D array? Or a 2D array?
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 13 of 22
(2,100 Views)
@GredW your solution is right for 1D Array i was not able to explain it earlier. It gives the write answer and sorry about it.
And @ikaiser is saying it right it was my bad i didn't explain it better
Message 14 of 22
(2,090 Views)
"write"  or "right" ???
Message 15 of 22
(2,088 Views)
here the result of what i got from your solution
Message 16 of 22
(2,088 Views)
@RavensFan  nice catch corrected it
Message 17 of 22
(2,086 Views)
Hi hasnain,
what's wrong with result 121?
Every "B" is replaced by either "0" or "1", and you got 16 rows from your input vector containing 4 "B" elements!
Message 18 of 22
(2,084 Views)
there is nothing wrong with the result it is the right one @GredW
Message 19 of 22
(2,077 Views)
Nice!
Does that mean your original question is answered, Hasnain?
CLADMSD
Message 20 of 22
(2,074 Views)
