09-16-2009 01:32 PM
Hello people..
I have recently undertaken some project which requires user authentication ,I have made a test VI from collecting some pieces of examples.
Apparently there are some issues about this VI which I made
Please somehow if you could do that for me it will be of great help
Thank you
09-16-2009 01:35 PM
09-16-2009 01:37 PM
09-16-2009 11:08 PM
Im really sorry ..
I forgot to attach.here it is 🙂
09-16-2009 11:25 PM
1. If you make changes to a front panel item of the VI and want to make those changes permanent, you need to right click on the control and select Make Current Values Default and then save the VI.
2. Your front panel path control is empty. If it is empty when you run the VI, then it will pop up a dialog asking you what file you want. To prevent that, place a file path in the path control.
3. Not quite sure what you are saying. But you are using the Quit LabVIEW function which will shutdown LabVIEW completely. You probably want to use a front panel close VI method on the current VI. I don't know the exact way that looks at the moment, but if you search the forums, you should find an example.
05-29-2010 03:08 PM
I do not really get the code, tried to run it several times, can you explain it more please?
05-29-2010 04:20 PM - edited 05-29-2010 04:21 PM
@Bharath kumar wrote:
2. The file that I write as text keeps prompting me to save the file as textfile no matter what I give in the path.I just dont want that I just want the file to be saved as a particular file in my harddrive without being prompted for name and path.
3. As you have noticed in my VI.the vi closes to open a new one if the username and password are right.I just want the login window to close after I enter the right username and password.
