User login - NI Security
Hi everybody,
I defined the security parameters of my VI and I found a problem with User login box and the NI Security-Open Session, so when I click on the cancel buton of ich one it launches LabVIEW and  acesses to project , and I have the same problem whene I click the cross .
I attached file wich shows the two boxes.
(3,168 Views)
U mean you want to define your username and password?Can you post ur Vi or a screen shot?
(3,131 Views)
Hi muks,
I defined my username but the problem is that when the login box apear's on the screen everyone wich click the cancel buton can access to my project and can do any modifications on it !!!!!!
(3,120 Views)
I'm confused by the description of your problem.  Are you trying to create a login session to protect you code within the project?  or are you trying to create a login session when you run your code?
If in the project, does it look like the image below?
R
Message Edited by JoeLabView on 07-22-2008 06:58 AM
(3,115 Views)
Hi JoeLabView,
Thanks for you help Smiley Wink
(3,099 Views)
Hi JoeLabView,
(3,098 Views)
