Check out all files of a LabVIEW-Project
We are using LaV 8.5 and Visual Source Safe in a large project.
How can I easy check out all files in my LabVIEW-Project (.lvporj) direcly in LabVIEW, without using Visual Source Safe.
Do I've overseen a simple solution for that?
Actually I have to open al folders /structures, select all files the chcek out.
Message Edited by zav on 07-22-2008 01:39 AM
(2,698 Views)
If you select a (virtual) folder sub-items will be checked out as well.
This is not valid for library folders (lvlib/xcontrol/lvclass) where only the library itself will be checked out.
Ton
My LabVIEW Ideas
(2,681 Views)
Thanks for the fast response.
Exactly that's my problem: I'm working with multiple lv-classes in my project and for editing them, I have to check out all vi including if they are in (virtual) folders
(2,676 Views)
You can also expand all items in the project and multi-select them all. Then you can select to check the selected files out.
George M
(2,655 Views)
