User input and string catonation to store data in existing folder
I want to save my data to an already existing folder on my server (X:\). The user needs to input the job #, for example, 936888. I want the data to go to this folder on drive X:. I have tried to use the "build path" vi to combine the user input of the folder number with the path.
(2,597 Views)
In the string palette, there is a subpalette called String\Array\Path Conversion. Convert to and from strings and use Concatenate String to build the path and convert it back to path.
___________________
Try to take over the world!
(2,586 Views)
If probably easier if you use the array of strings to path function.
Take a look at the attached vi.
Hope this helps,
Paulo
(2,584 Views)
Hi Ronman !
Try this...
Chilly Charly    (aka CC)
(2,580 Views)
