Hi Ronman,
For any express VI, you can right-click the express VI and select "open front panel". LabVIEW would then prompt you if you really want to convert the express VI to a standard VI. If you click on the "convert" button your express VI would change to a standard VI and you can then view the block diagram of the VI. You can make any changes in the block diagram.
Do remember that once you convert the block diagram of an express VI, you cannot go back to the express VI mode.
Hope it helps.
Ankita
