Use of "IVA Coordinate System Mmanager"?
I do not understand how the vi "IVA Coordinate System Mmanager" is used. When I do create the LV-code from the NI Vision Assistant it gives me following fragment:
Here the "reference System" input is set (the x-/y axis) automatically to the value 562.95 and 558.641 (see picture above). What indicates those values if I do pattern matching? And to which values I need to set it for any image where I do pattern matching? The output of this vi gives me a cluster with the origin and the measurement system. Even I set those two values to 0/0 it gives me the corect and new coordinate system of the found pattern but I'll get an NaN if I use the same function (pattern matching) twice in a row for a different image. In both cases NI Vision Assistant sets those two default values automatically.
thanks..!
Message 1 of 8
(4,972 Views)
I am guessing you have tweaked with the location of IVA files.
the default location is C:\Program Files\National Instruments\Vision Assistant 8.0\CG
Message 2 of 8
(4,960 Views)
muks
my question was not about the .lib location! I was refering to the setting of the values for the "reference system" (see text above).
Message 3 of 8
(4,942 Views)
Hi Norick_17,
can you post the Vision Assistant Script File?
Cheggers
Sascha
Message 4 of 8
(4,911 Views)
I have attachted a script file. Here u can see that the coordinates for the reference system has been set to the values where the coordinate system is.
Question: Why are this coordinates (87.45/221) already set? Does it matter if I set the values for the reference system to 0,0?
best regards
Message 5 of 8
(4,833 Views)
I think cheggers asked you post the .scr file.
Message 6 of 8
(4,830 Views)
Message 7 of 8
(4,822 Views)
how to set "reference System" value?  or how to compute it ???
Message 8 of 8
(4,334 Views)
