‎04-27-2011 02:17 AM
‎04-28-2011
02:01 PM
- last edited on
‎01-12-2025
02:28 PM
by
Content Cleaner
Hello ktq,
There are a couple ways you can control a VI front panel. The best way is through web publishing, How do I publish my VI to a web page? You need to be sure about firewall permissions and issues on both ends. Also check out our Internet Toolkit. Are you hoping to do this on a network? Depending on what your application is, you can also run network streaming queues through ethernet. Please let me know if you have any questions, good luck with your application!
Deborah Y.
‎04-29-2011 04:18 AM
‎05-03-2011 10:37 AM
Hi ktq,
It is possible to use such a web service to make your data available anywhere online. The catch is that you cannot code on the block diagram, everything must be done through a front panel control. Error handling as you mentioned, would be possible here. How elaborate is your front panel? If you need to change code it may be more beneficial to set-up service to remote in to the computer and have full access to the code.
Deborah Y.
‎05-03-2011 10:53 AM
‎05-04-2011
02:40 PM
- last edited on
‎01-12-2025
02:30 PM
by
Content Cleaner
Hello ktq,
Here are some help files to get you started, besides the 'How do I publish my VI to a web page?' from above: Configuring, Running, and Managing the Application Web Server, Enabling the Application Web Server for Web Services. Please post if you have any more specific questions along the way as you get the application started.
Deborah Y.
